‎2009-06-12
05:14 PM
- last edited on
‎2023-05-26
03:26 PM
by
Rubia Torres
‎2009-06-12 06:12 PM
If the file you brought across had layers which were not is exact numerical order for the in index values (for example, it had 1=Walls, 2=Floors, 3 was unused because it had been deleted, 4=Roofs) after "appending" the layers across you would not have the same index values (in the example you would end up with 1=Walls, 2=Floors and 3=Roofs). But a layer combination that originally showed the Walls and the Roofs but not the Floors (show layers with index values 1 and 4 only) would still try to show those index values (but since Roofs isn't 4 any more it would be incorrect).Hope that maybe helps somebody.
