2006-02-18 11:10 PM - last edited Wednesday by Molinda Prey
2006-02-19 08:53 PM
2006-02-19 09:25 PM
2006-02-19 10:02 PM
2006-02-20 11:50 PM
s2art wrote:Or take a look at OBJECTiVE. It's an add-on for ArchiCAD which provides 3D rotation and different working planes for objects. The announcement (and links) are at
I think I know what you mean, Vivi. In AutoCAD you can rotate your working axis (UCS = User Coordinate System) so that you can perform a normal rotation on a object in a direction other than that seen on plan.
This can't be done in ArchiCAD, unless, as Matthew says, an object has that parameter in it's make-up.
Try looking in the GDL / Library parts forums for ways to do this if you want to get into GDL scripting (way beyond me!)
2006-02-21 12:05 AM
