studioob112
Schedules question ?
Question ?...
Hello everyone i hope you have a great Monday.
How can i make costume custom Schedules in my Archicad, where i live we use other kind of template of the Schedules of the doors and windows so my question is is that possible to achieve to make that in Archicad and to be automatic by the archicad or should i link with excel ?
For the moment i do the Schedules (manual mode) i do by myself in ground floor i start by using lines and create my template and do the work so its a lot of manual work, im asking is there any possible way for more easy way, bc every country has their own standard of work as architect.
Anyone who will text i say Thank you so much
Setup info provided by author
Can you show an example image of the custom schedule you want?
Ricardo Lopez
Hi @studioob112
As @Barry Kelly asked, it would be great if you could share a screenshot of the desired schedule.
Anyway, Archicad has a good scheduling tool where you can display lists with fields, properties and parameters for elements, components and surfaces.
You can find more information here and  there is also free course available on the subject: Get Started with Scheduling in Archicad
Best regards.
Ricardo López, M. Arch.
