Project data & BIM
The lowly line tool
I've had the experience twice in the last two days of lines not being able to select lines on the drawing, even after turning on all layers. Once I was attempting to create a custom profile by drawing a series of lines, highlighting them and activating "offset" from the pet pallette. The offset line was achieved and highlighted, but I could not highlight the original line. The second time was today. I highlighted a line to drag it upward to a new location, which was successful. However, there remained the original image in the original location, which I cannot select because it does not respond. I am left with a line in a location that I do not want. Weird.
15 REPLIES 15
Link wrote:
Couldn't agree more about the Info Box, but I noticed you still have your Navigator Preview on. I turn to turn mine off nowadays. Do you find yourself using it much?
I use it quite a bit... fast way to zip to different locations in a project at the same zoom... e.g., if I'm doing something in all of the corners of a building - zoomed in for corner boards, or structural stuff. Kind of used to moving the zoom box there for panning since it's so much like Photoshop / Aperture navigation when zoomed in.
Hope to see you on the 5th! 😉
One of the forum moderators
Link
I think ever since I got my new Logitech Mouse with the free spinning wheel which lets me zoom in and out like a crazy man, I've relied less on the Navigator Preview.
Have you tried one? They're very addictive. Not sure I could go back!
See you soon!
Link.
I checked trace reference first thing and even rechecked it later and that wasn't it.
One thing about it was it responded to my layer settings. I shut the layer off the grouped lines were on and the ghost lines shut off as well and reappeared when I turned the layer on.
I think I went from plan to 3d back to plan to get it to finally go away.
Something like this happened a few years ago to me and it was a real issue then. Can't remember the details but the offending object was a wall with a complex profile applied to it. After sometime I went to delete the all instances of the profile and one of them stayed, wasn't selectable, had no hot spots, and keyboard commands had no affect. Had to copy my work to a new project to fix it.
Thankfully that wasn't the case this time. Trust me, when it happened I was seriously bummed out as I was just starting to draw a series of custom windows and doors for the project and the lines that I couldn't interact with were right in the middle of what I was doing. Made what I was doing unnecessarily confusing. And on the back of my mind was the possibility of having my current "template" corrupt and I would have to revert to an older project and lose work because of it.
But I also wouldn't be surprised if it was just a glitch on my computer and not Archicad per say.
Link, I have the Perfomance Mx mouse from Logitech.
http://www.logitech.com/en-us/product/performance-mouse-mx?crid=7
I agree, the free spinning mouse wheel is pretty much a must now for me. Hate using my other mouse, especially on long webpages where smooth scroll scanning works great with that mouse wheel feature.
I also have the two thumb buttons on mine that's like on yours set to up one story and down one story. Click it and anywhere in the project pulls me right to plan view. Very very useful for me. Wish I had two more buttons for up one layout and down one layout as well.
I'm still guessing you have a trace of the same floor plan view point from the Project Map.
It will respond to the same layers because anything in the Project Map uses your current layer settings.
Only a trace of a view in the View Map will not respond to you changing layers as the view has its own saved layer set.
Ernest Atanasiu
Karl wrote:
Kenneth wrote:
how you transferred the WE to vertical. I haven't yet tried it. It may be straightforward.
[Apologies to others for being off-topic...]
Just drag and stretch. Also, for the Info Box, you need to change the header position. Not sure why it is not automatic... but right click the header of the Info Box and you'll get the attached pop-up. To save your revised palette positions and sizes (includes all dialogs such as Layers Dialog, Drawings, etc.) - save (with your own name, the first time) or update (subsequent) the Palettes Scheme in your WE.
The info box header position is not visible if the palette is docked to the side of the screen. In Windows, this is automatic and that option has no effect, unless you have 2 monitors and you keep your Info Box on the 2nd monitor.
sorry for the offtopic
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
Karl wrote:
As Barry noted, if the T&R palette is not visible, you may not be aware that T&R is turned on. For that reason - and ease of access - I always have that palette docked with my other palettes as shown in the attached screenshot of my normal Work Environment. Any organization that works for you is a good organization of course. 😉
PS As a tangent / off topic... I continue to be frustrated that Graphisoft's default WE has the Info Box horizontally at the top of the screen... which let's you view... and modify... very few settings. I wish they would distribute a few Work Environments (WE) so that new users could try working with the Info Box at the side as shown here... where it scrolls vertically with the mouse 'wheel'. My experience is that most people just work with what is delivered, assuming that Graphisot delivered it as an example of 'best practice'. But, best practice is what works best for you... and exploring the Work Environment options is worth the time. OK; off my soapbox. 😉
Im going to give your layout a go
What settings did you use to get the yellowish look for your cut section images by the way??
thanks
