Viewing and comparing multiple designs choices
Hello, I am rather new to ArchiCAD. I was wondering if there is a simple way to save multiple views of alternate design choices?
For example, let's say I want to compare what a room looks like with red carpet and blue carpet. How can I save two views of the project, one with red and one with blue carpet that can be quickly compared? Views don't seem to save material attributes, instead displaying only the current values.
Layouts appear to be for documentation and publishing. Putting each colored carpet on a distinct layer would create redundant objects. Creating separate project files for each distinct attribute would rapidly grow impractical. Am I missing something obvious?
Thanks,
Kerry
4 Replies 4
With layer combinations and saved views any number of variants can be achieved: I have done this on a residential aprtment project successfully displaying adaptable housing furniture layout alternatives for residents requiring special access needs.
Another method usually recommended is to use Hotlinked Modules for the Design alternatives. You can search for it in the Forum, it has been discussed several times before.
When the design alternative consists simply of material assignments, an easy answer is attribute manager (AM).
Create a new material called 'conference room carpet' (e.g.) that is a copy of blue carpet for your example. Put a space in front of the material name so that it sorts to the top of the list. Repeat for other elements.
In AM, select those materials (or all materials), overwrite (NOT append) to the right and save in a file called 'Design One' or whatever. Change the materials to your second design choice. Repeat. Now, just use AM to load the materials for each design choice.
When the design is physically different, then I would go to the approach of using layers, hotlinked modules, or markup tools. When it is only different in surface or edge appearance, I would use attribute manager.
Link
A few discussions to help you:
Material change as per Karl's suggestion is here.
Using Teawork for different building design alternatives is here.
Link.
