Wall Fills
I had a floor plan that had all my walls set as marker fill, but after I played around with some layers to create my RCP, some walls were no longer filled. And now, when I try to draw a new wall, it won't fill in. The weird part is that it says it is filled when I click on it. Please help.
David Maudlin
lcomleyCSA:
Check the Cut Fills under Options for Display & Output by going to Options>Display Options... You should create a named Display Options Combination for the display settings you want for each plan type as these are saved as part of the view set (like Layer Combinations are also part of the view set).
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
