AndrƩ:
If you imported an older Work Environment, the Attribute Manager will not appear as they changed the command. If you go to Work Environment > Command Layout Schemes > Menus, and set the List to All new commands in alphabetical order, you will find the new Attribute Manger... command; add it to your WE.
David
