Learn more
attributes manager
hi,
I have the 22 portuguese edition and I don't have the attributes manager.
at 21 I had, but 22 not.
may you help me?
1 Solution
David Maudlin
André:
If you imported an older Work Environment, the Attribute Manager will not appear as they changed the command. If you go to Work Environment > Command Layout Schemes > Menus, and set the List to All new commands in alphabetical order, you will find the new Attribute Manger... command; add it to your WE.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
1 Reply 1
David Maudlin
André:
David
