layer settings
hello,
What is the relationship between the layer settings that are generated from the plan and 3D view and the layer settings generated from the Layout views?
I have noticed that my Schedules pasted on the Layouts are effected as I change the layers settings of my model. Is there a way to avoid this?
Thank you in advance
TomWaltz
The layouts have the same layers on as the last window you had open (or is it the plan window? I forget).
The only real solution is to put everything on layouts on the Archicad layer.
Tom Waltz
