OMG, that 'funny box' was the answer to many wishes and prayers and vastly speeds up maintaining layer combinations!
If you select a layer (as you have - zSEO's is your selected layer - you can read the name in the column heading), then the values in the circled columns are the values of THAT layer in EACH of the layer combinations.
So, you can just run down the entire list of Layer Combos and change the lock, visibility, wireframe and intersection priority of that layer in all combos just by clicking buttons ... and with no need to click Update.
Further, for any layer, you can READ its values in all layer combos - to determine if something is amiss with your intersection priorities, etc.
The old way of updating layer combos still works of course.  Select a Combo (rather than a Layer) and then change the status values of any layers ... and THEN click the Update button in the combo (left) panel to update the combo to the current layer settings.
