2006-01-0305:56 PM - last edited on 2025-01-2903:06 PM by Molinda Prey
2006-01-0305:56 PM
I am fairly new to archicad, at startup and library load, i recieve the report of a missing zone stamp, my zone tool does not work, and browsing down to the zone stamp box, it reads---"Not available in the loaded library" Can you help!!!
The zone tool uses library parts called zone stamps to place the room name text etc. The zone tool settings define what stamp is used with each zone type. If the stamp defined in the settings is not in the loaded libraries you will have this problem.
The solution is either to load the necessary libraries or redefine the zones to use stamps that are loaded.
