Project data & BIM
shortcut for the magic wand??
I need help finding magic wand in archicad.
I heard that some of you use a shortcut for magic wand by pressing spacebar but it doesn't work in my case.
I am trying to make a terrain based on layers exported from dwg file. I watched a youtube video describing the whole process. But the guy used spacebar for magic wand, and I can't find it anywhere.
Do you know where to find it or what to type?
What is the simplest way to make a terrain from layers??
Thank you for advices!!
4 REPLIES 4
It's the space bar.
David Maudlin
sloArchi:
Also, there is a button for activating Magic Wand in the Control Box palette.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for responding! I must apologize, because after asking about the problem on forum, I tried again and it worked - it's the spacebar, but I didn't hold it, just click it, which is stupid, I know
Thank you anyway!!
David Maudlin
Sanja:
Thanks for posting back with the solution, welcome to the forum.
David
