2012-06-19
01:43 PM
2023-05-30
01:11 PM
Rubia Torres
2012-06-19 03:20 PM
mzex wrote:This has been the case through multiple AC versions, but the settings are correct, so don't worry about it.
Problems is after I assign my work environment and press OK, I go back to settings and I can see that palette scheme and work environment scheme is set to custom.
mzex wrote:The Tracker getting turned off is a bug, some use a menu command or toolbar button to turn it back on easily.
Even though setting in custom and marko scheme are the same, sometimes it turns off some of my settings (show tracker gets turned off)...
2012-06-19 05:52 PM
2012-06-20 03:01 PM
2012-06-28 07:59 AM
2012-06-28 08:26 AM
mzex wrote:It is dockable in 15 but doesn't seem to remember if it was turned on when you shut down and restart.
just tried it in AC 16, and position of quick layers are stored in WE settings.
2012-06-28 10:51 AM
Barry wrote:I do know that it is dockable in AC15, it was possible in AC14 and so on. But the problem was that it was not remembered by WE.mzex wrote:It is dockable in 15 but doesn't seem to remember if it was turned on when you shut down and restart.
You can set up a tool bar button in the work environment to quickly switch it on or off.
The default keyboard shortcut should be "ALT-Q" on Windows.
2012-06-28 11:38 AM
2012-06-28 09:48 PM
2012-06-29 12:27 AM
