General information needed, i.e. overhangs
I am trying to use the energy modeling in AC17 to look at solar heat gain of different orientations, window locations and shading devices. Is this possible?
I am concerned because in the Opening Properties under shading device there are many options one of which is overhang. All of the characteristics of this overhang would be necessary in order to truly model the solar heat gain from the window, but you do not input any of this information. Is there another menu or is the model reading the beams that are modeled above the window as a shading device or the roof overhang to determine the location and characteristics of the overhang?
Is there a outline of how to read the Evaluation Report? I would like to see a document that goes through the information and explains how this information is calculated and what it is using to determine the information. Otherwise you do not know how accurate it is.
Any resources on how to use the feature would be appreciated. I have seen the webinars on the Graphisoft website, but that is all I know. Other resources?
Thanks,
pam
You can review the properties of shading device from
Graphisoft/ArchiCAD 17/Add-Ons/EnergyEvaluation/AUS(or USA or INT)/ShadingCatalog.xml
Here, you can adjust or add more shading devices.
Kevin,
Have similar question...is that reference you gave before still good ?
Thanks!
