MMMR
Way to change the visualisation of the thermal bridge simulation?
Hey!
Is there a way to change how the coloring shows the temperature? Id like it to stay a shade of the red until it hits 0 Celsius then go blue below 0.
Thanks in advance.
2 Replies 2
Ricardo Lopez
Hi @MMMR
Apparently, the visual scale is fixed to the temperature range you choose for the exterior and interior. If you choose -20 and 20, the average value will be 0, but I guess that wouldn't be a realistic scenario for you.
Ricardo López, M. Arch.
MMMR
Hi, thanks for the reply.
Unfortunatly not. I need the coloring to be based on the materials in the composite so the visuals give a more accurate representation of the actual thermal bridge 🙂
