2021-04-08 03:21 PM
Solved! Go to Solution.
2021-04-12 11:08 AM
Noémi Balogh
Senior Community Expert, Admin
2021-04-12 11:08 AM
Noémi Balogh
2021-04-12 12:56 PM
2021-04-12 06:21 PM
2022-12-03 11:18 AM
Please, I am having this same issue on my AC 22. What file can i delete?
2022-12-04 03:55 AM
If you got this error that was mentioned in the first post ...
"Error while opening the file: C:\Users\Username\Graphisoft\TWData\TWDataOptions.xml"
Then that is the file Noemi is referring to.
If you did not get that same error, then you will have to supply some more information.
2022-12-17 08:40 PM
Face similar issue on Archicad 24 but when deleted Twdata option.xml
It works perfectly and the file opens successfully.
Thanks
2023-08-02 10:58 AM
I have the same issue but I can't find the TW data file, some advice please
2023-08-02 10:59 AM
Where did you find the TW data file
2023-08-05 11:04 AM
Hi Safari,
In response to the issue,Goto programmes files:-
Programmes files - Graphisoft -Archicad 24 - C -rollbackBackupDirectory- TWdata option.xml and then delete.
Thanks
