AC 24 "Cache File Opening Error" at start-up
So today while I had ArchiCad 24 open, I had a sudden power cut. As a result, my PC shut down while I was working on the program.
After restarting, I tried to re-open Archicad and got presented with a
"Cache File Opening Error" at the start-up screen. It reads,
"Error while opening the file: C:\Users\Username\Graphisoft\TWData\TWDataOptions.xml"
I can click "OK" but it just pops up again until I force the program closed.
I have tried to re-install, but the same issue comes up again.
Any suggestions for a fix?
1 Solution
Noemi Balogh
Hi Sejal,
I'm sorry to read about your issue.
Did you try to delete the xml file from the path?
I think we don't delete the TW Data folder and its content when you uninstall Archicad, so this case if the xml is corrupted, a re-install does not solve the issue.
Kind regards,
Noémi
Noémi Balogh
Staff Community Expert, Admin
Go to post
9 Replies 9
Noemi Balogh
Hi Sejal,
Kind regards,
Noémi
Noémi Balogh
I tried deleting the file. .It works now thanks
Hello Sejal,
I'm happy that Noemi was able to solve your issue!
As a new user - and a reminder for others reading this: PLEASE make your topic subject as complete and informative as possible so that knowledgeable people will answer, and people with a similar issue can find the thread and the answer later.
You'll see that I've changed your original subject "AC 24 Issue" - which pretty much is meaningless to:
"AC 24 'Cache file opening error' at start-up" which precisely describes your problem.
Welcome to the forums.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
chrisea
Please, I am having this same issue on my AC 22. What file can i delete?
If you got this error that was mentioned in the first post ...
Then that is the file Noemi is referring to.
If you did not get that same error, then you will have to supply some more information.
Yakubu1967
Face similar issue on Archicad 24 but when deleted Twdata option.xml
It works perfectly  and the file opens successfully.
Thanks
safari joseph R
I have the same issue but I can't find the TW data file, some advice please
safari joseph R
Where did you find the TW data file
Yakubu1967
Hi Safari,
In response to the  issue,Goto programmes files:-
Programmes files - Graphisoft -Archicad 24 - C -rollbackBackupDirectory- TWdata option.xml and then delete.
Thanks
