AC13 closes a teamwork file without asking to save
This has happened several times now. I have a teamwork file open and working. Have not completed a command-s to save or even sent/received sense last operation. Going through finder inadvertently double click on a dwg file instead of opening with my viewer app.
AC13 teamwork will close that teamwork file and open the new file without asking to save or send receive.
Is this a bug or is there a setting we are missing?
Thanks,
2 Replies 2
Sounds like a bug. In the meantime I would recommend that you set your viewer as the default program for opening DWGs.
Good advise.
I did reset after my post earlier.
I hope GS programers pick up on this one.
Thanks
