Archicad 22 team crashes when saving PLN
So we faced a problem that every time we try to make a reserve copy (save PLN on computer) of our team project (ARCHICAD 22) Archicad crashes.
does anybody know what could possibly be the cause? Thank you in advance for tips
4 Replies 4
hybrid
Hi.
1. Different files?
2. Only your Archicad? Or everyone?
3. Have you got the latest update? If not, install the update from here https://graphisoft.com/resources-and-support/downloads?localization=%E2%80%93&type=AC&version=22
AMD R7 2700 3.8@GHz | 32 Gb RAM | SSD | GTX 1050Ti
hybrid wrote:
Hi.
1. Different files?
1. only one of our team project do that, other teams work just fine
2. this happens on every computer and no one from this team project could save it in pln
3. and yeah, we use the latest version
Podolsky
Ace
It's most likely corrupted file. You need somehow save PLN. You mentioned that ArchiCAD crashes while saving PLN - when you are trying to save manually or when BIM server is saving a copy? In any case you have two options - or save PLN manually or extract from BIM server.
After you need open the file with option open&repaire function chosen. And re-share the project.
Aaron Bourgoin
I'm not so sure it's the file you're working in. If more than one file (solo or teamwork) crashes, do an uninstall and re-install. We had this problem chronically on selected workstations in the office. That solved the problem.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
