Nizar Eisa
whenever I press the Save Archicad 27 , it crashes
hi
whenever I press the Save Archicad 27 , it crashes, and bug reporter pops up. tried restart ,nothing.
4 Replies 4
When you open the file, can you check the "Open & Repair selected file" checkbox? see if that helps with the crashes?
There is also a Support Article that says making sure no View has a "MISSING.." settings could also help. It may not be your exact scenario, but it is worth checking out:
https://support.graphisoft.com/hc/en-us/articles/30684325916945-Archicad-crashes-when-working-on-lay...
Lingwisyer
Guru
What is your computer memory utilisation like with the file open?
Just one particular file or all files?
Dominik Nagy
Hello!
We are familiar with this issue, and we are currently investigating it.
What we know so far that it is caused by WPS Office Cloud shell extension, and Archicad will crash if the file explorer will pop up (like exporting, opening or saving etc.)
In similar cases there were 2 solutions for this issue:
1. Temporarily disable  WPS Office Cloud shell third-party shell extensions while we will try to fix the issue or
2. Run Archicad as an Administrator.
I hope that it will fix the issue for you as well!
