Nizar Eisa
whenever I press the Save Archicad 27 , it crashes
hi
whenever I press the Save Archicad 27 , it crashes, and bug reporter pops up. tried restart ,nothing.
3 Replies 3
When you open the file, can you check the "Open & Repair selected file" checkbox? see if that helps with the crashes?
There is also a Support Article that says making sure no View has a "MISSING.." settings could also help. It may not be your exact scenario, but it is worth checking out:
https://support.graphisoft.com/hc/en-us/articles/30684325916945-Archicad-crashes-when-working-on-lay...
Lingwisyer
Guru
What is your computer memory utilisation like with the file open?
Just one particular file or all files?
