BIMServer 21 Update (3005 -> 5010)
Hey,
I installed BIMServer 21 from the INT download page, tried to connect from an Archicad client and I was told the server version was too old for this client.
I then updated to version 5010 but the error persists (client says server is running 3005.)
When I access the web interface modules page, the Manager is shown as running the newest version, but the Module is shown with the older one.
Am I doing something wrong? Have I ran into some bug? Thought someone around here might be able to help out.
I'm having the exact same problem.
Tried a fresh clean install, different java versions, applying all bimserver updates one by one in order, nothing works.
Only the Bim Manager gets updated, the Module stays at 3005.
The weird thing is that i checked the exe for the module and in the details it shows that it is updated!
I'm out of ideas...
I found out what i was doing wrong.
I needed to activate the first install, then apply the updates.
So, install the base first, activate it, then apply the updates.
