Teamwork & BIMcloud
About Teamwork, BIMcloud, BIMcloud Basic, BIMcloud Software as a Service, network settings, etc.
Bim server libraries
My contractor is in another country and we are trying to set up teamwork. The model is on my machine. I can access and edit fine.
She is having problems with the libraries. I have assigned her admin rights but we still can't get it to work. So my question on the libraries is, where should they be based. Ie should she be repathing the libraries to a local library on her machine? What is the fastest set up as it is so slow as to be unuseable at the moment.
Hope this makes sense.
10 REPLIES 10
Has anyone been able to find a solution to this problem?
Just to be clear, is this the issue others are having:(see attached)
-Manage BIM Server Libraries
-Select Library
-Remove
-Warning
-Remove
Then nothing!
