‎2024-04-30 04:40 PM
Hi, i created a Bimcloud basic server. How can i add other people to work in my server? I have the server addres but when the other person adds it, it give me an error. I saw online that in the user setting ther's a method to invite user with GSID but i assume that its an option for upgraded versions of Bimcloud. is there a method to work with 2 separate PCs with separate users with bimcloud basic or is it a feature for upgraded versions?
Thank for the help
Solved! Go to Solution.
‎2024-04-30 10:10 PM - edited ‎2024-04-30 10:11 PM
You can add users to your BIMcloud basic server if they can access the location of that server within your local network.
The user should only need the server IP address to connect.
Short test to check the user connection to your server (from user computer):.
You can also heck BIMcloud clean installation step by step >> HERE <<.
Regards. -
Regards. -
‎2024-05-03 08:18 AM
Thank you very much
‎2024-11-08 09:44 AM
Hello!
I am about to create a Bimcloud basic server for our office. I am not sure about the steps. I start by installing BIMcloud from my computer? What I should install on our local server? Can I some help, pl?
‎2024-11-08 10:56 AM
Check this out: Getting Started with Graphisoft BIMcloud Basic
Noémi Balogh
Senior Community Expert, Admin
