Can't delete a library from the BIM server
Hi there, I hoping this error has happened before. I am having trouble updating a BIM server library. I selected delete and nothing happens?? I am using 'manage bim server libraries'. I was able to delete other libraries on the BIM server, just not this one. The filepath is to a computer I am no longer using. I need to update a library with a new one. Also can't 're-locate' the library as is says 'there is already a copy of this library on the BIM server'. Do I need to get into the BIM server from the back end?
0 Replies 0
