vfrontiers
Cannot Write TEAMWORK notes
I get this error while trying to sign in for the first time into a file that has 2 others already signed in. This error shows 3 times, then another error dialog displays....
"This name is in use by a locked document select another folder or use a different name"
Then the file quits.
1.The NAME I use to sign in does not matter.
2. Happens on several machines.
3. The file is an OPEN member type.
Any help?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
4 Replies 4
Network permissions maybe?
Karl
vfrontiers
Karl,
I'll check into it tomorrow.
It has been somewhat of a struggle trying to integrate MACS into our PC office. We've now decided to use our PowerMAC as a Fileserver and I can't seem to get the new folders created to take on the permissions of their parent (automatically).
I believe I have checked this, but maybe you're on to something here. Although... I am signed in (as ME) on my machine, but trying to sign in as another person, I even get the same message.
Not fun when deadlines loom (of course, when don't they!)
Duane
Visual Frontiers
AC3.14 - AC29
Duane,
Someone here just had this "Cannot Wrote Teamwork Notes" message pop up today. Did you ever determine what causes it? We are also on a mac network, but it only recently appeared for the first time.
vfrontiers
Not sure if I really found out what CAUSED it, but I did solve the issue! We bought all macs for the office and installed a MAC Server.. w/ server software. Setting permissions is better with the server software, which I suspect was the crux of the problems...
Duane
Visual Frontiers
AC3.14 - AC29
