Default snaphot settings
Whenever a new project is shared on teamwork, I need to manually go into the project settings and change the snapshot settings from 10 hours to 1 hour.
Is there a way to adjust the default setting, so all new projects have the above interval set?
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
1 Reply 1
Noemi Balogh
On BIMcloud and BIMcloud as a Service it is an available option to schedule snapshots from the root folder, so this is easy to achieve. In case of BIMcloud Basic, the only way unfortunately is to schedule project by project.
Kind regards,
Noémi
Noémi Balogh
Staff Community Expert, Admin
