Hi Eric,
First of all, the alternate address you put into your list has a typo: bimclould. If you have the bimcloud.EDAProjects.com, then possibly it won't work with this. : )
But based on your comment, I suspect you don't own such Fully Qualified Domain Name (FQDN) (see also:
https://en.wikipedia.org/wiki/Fully_qualified_domain_name). Without a FQDN or a fix public IP your consultant won't be able to access your BIMcloud. The primary address, which is probably your computer's own IP. It is available through your own wifi, but it is likely that this is not public as well.
It might worth to rent a FQDN or a fix IP from your internet provider.
Kind regards,
Noémi Balogh
Staff Community Expert, Admin
