Teamwork & BIMcloud
Migrate BIM Server Project Data to External Drive - tips?
Hey everyone,
I need to migrate the project data and libraries to external hard drive since the current location is beginning to run out of storage space. I'd like to ask if there are any tips/advice, or issues I should be aware of in this process.
My plan of action is to do this on the weekend when no one is working. Simply copy all of the project files to a new external hard drive, and then change the path from the BIM Server Control Center Preferences (Default Project File Location settings).
We currently run projects from Archicad 14 with a module for Archicad 17. We also use a Mac Mini Server, where currently the BIM Server + Project files are located on a partition.
Thanks in advance!
0 REPLIES 0
