Learn more
Problem with .PLN backup
we're having problems with .PLN snapshots in BIM Cloud.
For all of our project, BIM stopped making PLN backups about 1 month ago, they all froze at PENDING status.
I've tried stopping and changing the schedule.
Restarting the server and services.
But nothing has helped
The BIM Projects backups are working fine, but the PLN backup isn't even making a backup folder inside the project folder. It just freeses.
Any help would be apricieatred.
Best Regards,
Mateusz Pawliński
3 Replies 3
Noemi Balogh
Hi Mateusz,
I suggest to check out this Help Center article: https://helpcenter.graphisoft.com/knowledgebase/86822/
It will guide you how to solve this issue.
Kind regards,
Noémi Balogh
Senior Community Expert, Admin
Hi Noémi,
thank you for you're reply.
I've already tried rescheduling all projects tasks, unfortunatelly with no luck.
The other thing I've checked is that there are no new log files created / modified straight after running a backup.
Further help would be aprecieated.
Best Regards
Mateusz Pawliński
Noemi Balogh
Hi Mateusz,
I will contact you in PM with further details. It seems we need to investigate a bit of these issue.
Will post an update here when we know more.
Kind regards,
Noémi Balogh
