Project Status and Edit Project Names
Two part question :
1. I get an 'Error in submitted data (Error code 7)' note every time I would like to change a Project Name, on the BIM Server. Any suggestions? Is there another way to rename a project?
2. After I delete projects from the server, Teamwork displays them as 'Deleted from Server'. Reference image. I have been suggested to empty my internal cache. I did this and no luck.
Thanks for the help, ahead of time. - Jakub
2 Replies 2
Reference Image 02
Hi Jakub
Not sure which build you are on but the rename project error was a bug fixed in the now removed 5014 build update.I imagine you will have to wait for this to be re-released to fix this issue.
To remove the deleted project you need to remove the local copy
Teamwork>Project>Local Data Manager
Deleting them from here will remove them from the list
