2023-09-29 01:37 PM - edited 2023-09-29 01:38 PM
Hi all,
Yesterday we've installed the new Archicad 27 and are using BIMCloud Saas with Archicad 26. However, when trying to opening a project in Teamwork, the project folders are empty. Projects are vissible in Archicad 26, but not in AC27. Strangely enough, when I share a new project in AC27 to Teamwork, the projects are visible.
Any ideas? I allways understood it shouldn't be necessary to first open in AC26, save as pln. Then open in AC27 and share to Teamwork for all projects.
Thanks.
Solved! Go to Solution.
2023-09-29 01:57 PM
Projects hosted on SaaS should be migrated the same way as they were migrated with on-premises BIMcloud versions. You have two options: either run a Teamwork migration (https://help.graphisoft.com/AC/27/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC27_Help%2F010_Migra...) or via saving a PLN in Archicad 26 and re-sharing it from Archicad 27.
Noémi Balogh
Staff Community Expert, Admin
2023-09-29 01:57 PM
Noémi Balogh
