Teamwork and Modules
Hi!
Anybody know does what this error message means: "This name is in use by a locked document. Select another folder or use a different name."
I am working in Teamwork file and there are different modules, also other team are working through the server
Thanks
I used to have the same problem when there was a LCK file, or when for some reason Some user lost the "rights" to write on the Server.
It's not a huge problem since you can save your local copy, close archicad and then try it again.
In any case be sure everyone is using the same built, and there are no issues with the server.
Hope this helps
Nando M
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Thanks for the hint.
Thanks
