Stress Co_
Teamwork not sending/receiving messages
We're using Teamwork over a LAN and have been able to send/receive messages.... until now.
The "Show New Message Alert in Teamwork" box is checked in our Work Environment profiles.
Everything else seems to work as expected (reservations, send & receive, etc.)
Any ideas?
NOTE: This is using AC15 USA FULL build 3267
Lion 10.7.2 Grrrr
Marc Corney, Architect
Red Canoe Architecture, P. A.
2 Replies 2
Something has changed. I'd look first at all of your firewall settings and make sure the required ports are all being forwarded to the bim server's ip address. I find windows 7 has been notorious at modifying permissions without consent... it seems sometimes it will go out of its way to disrupt your entire network under the guise of "security" settings... and a single win7 machine on a mac network... grrrr... I've had them automatically adjust pnp router settings and block teh network to all traffic but its own.
Gaz
Stress Co_
Problem solved!
The server computer had an older version of Java than the other workstations.
Thanks to Craig @ Graphisoft Tech. Support.
