Also, it depends on how your internet is supplied. The wrt54g is only a router, not a modem. Presumably you have a DSL (or cable) modem that is connected to the linksys. That modem also (probably) has firewall settings that have to be opened to allow communication to those ports to get through to the router ... which will then forward them to the static local IP address of your BIM Server machine.
To access the BIM Server externally, you'll need either a static public IP address or a DNS name - see the Wiki articles.
See also this web site:
http://portforward.com/
for some device instructions (not 100% accurate, but close enough to help most of the time) ... and some free methods for verifying that your ports are accessible from outside without having to actually leave the office, come back, leave again, etc.
PS I have a friend whose ISP gave him a really ancient DSL modem which does not have a web interface, and so we were unable to open ports on it ... only a new modem would resolve that.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
