"Request Publisher Set" - Not working bug, Teamwork Status Missing
Trying to use "Request Publisher Set" but nothing happens, even there is no way to find out who is currently reserved Publisher Set.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v29 INT / NOR
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
6 Replies 6
Noemi Balogh
Is this the list of publisher sets, or is this one publisher set? I think reservation status is visible only on the publisher sets level and not inside a specific publisher set.
Noémi Balogh
Staff Community Expert, Admin
Publisher set can be reserved only as whole, not individual folders or files. Can you drop a print screen where Publisher Set Teamwork Status can be found ?
My case is that I press Reserve Publisher Set button and nothing happens, no screen asking to Request Reservation of Publisher Set.
Noemi Balogh
Left side I'm in one specific Publisher set and reservation status is not visible. Other side I see the list of available Publisher sets, this is where I see the status. Archicad 25 5005 I opened.
Noémi Balogh
Thanks I found that 🙂
Then there is issue, when someone have Reserved Publisher Set and another person wants to reserve it through specific Publisher Set like its shown on your left, reservation button does not make anything. When Publisher set is not reserved then it works.
If you wish to replicate this BUG you need to make following:
1. User 1 needs to Reserve certain "Publisher Set";
2. User 2 needs to go inside that certain "Publisher Set" that is Reserved by User1;
3. Press right mouse button and choose "Request Publisher Set" and nothing will happen no screen popup, no notification is given to User1 who reserved that certain "Publisher Set".
If that certain "Publisher Set" is not reserved by anyone then, Reserve function works well.
MaFarine
Hello,
Apparently we got the same problem.
Is there a fix on the way?
Thanks a lot for your help!
Mathieu Farine | BIM Manager | CCHE Lausanne | Switzerland
AC24-26 FRA | WIN11 | i7-9850H | 32Go | RTX4000
