360 Views on Webpage
I'd like to have something like this:
https://www.roomsketcher.com/features/360-view/
I want 360 views on my webpage of my model.
Best would be a dynamic model viewer that was connected directly to the BIM Server, but I guess that's out of the question.
..or does something like Revit 360 BIM Docs have that?
Any solutions?
1 Solution
I found this in the Help Center.
https://helpcenter.graphisoft.com/knowledgebase/84855/
Go to post
8 Replies 8
The Graphisoft solution is the BIMx web viewer:
https://helpcenter.graphisoft.com/knowledgebase/76004/
Right, but this can't display a 360 view from the model on a simple webpage, like the one I linked to right?
Tim Ball
BIMX works right in a web page, so you get the whole 3D navigation, all the drawings and all the data.
You upload to the BIMX portal and share the model by copying the url once you have uploaded. Then paste the link to your own website
An example from our website
www.jhdarchitects.com/how-3d-design-helps-clients
It’s quite heavy on data so you need a decent internet connection
Tim Ball
AC26, iMac
User since V5
It's something different than 360 views on webpage.
In contrast, this loads the whole model, where you can run around in it.
360 views are just stationary views inside the model.
That means I can present the home as a webpage, with stationary views from the kitchen, living room, bedroom, etc, in a simple manner.
This is too complex for normal people to use, while a 360 view is something easy for peanut brains.
Lingwisyer
Guru
Since a live connection does not appear to be possible, if your webpage supports it, could you not just embed a 360 render at the required quality?
Ling.
Hehe, that's exactly what I needed;) Thanks.
Szabolcs Miko
Yes, it's a very cool possibility to render 360 images, but you will need a plugin if you want to display it on the website. Facebook pages can display it automatically.
Szabolcs Mikó
Manager, Customer Support
