Chris Pooley
3D Perspective generates far too large PDF
Hi All,
I have had 2 jobs now where I have needed to "snip" a 3D perspective using the windows snipping tool and pasting onto the layout, rather than using a 3D perspective.
My preferred method would be to use a perspective, but something in my model or settings is having 2 negative effects:-
  1. taking a VERY long time to update when I open the layout or publish to PDF
  2. Makes my PDF's too large for my clients to view on their machine's.
I did not have this problems when I was working in A19. I am also not sure what I can show you to to show the problem I am having I have attached some images of my settings, but let me know if any other info would be helpful for troubleshooting.
Thank you
ArchiCAD 19 to 27
Windows 11
11 Replies 11
Botonis
Mentor
If trees are important try to use the 2d-3d collections of Archiradar with custom settings for 2d and elevations.
You will see a massive decrease of size and increase in detail as they have a lot of settings to choose from.
They are not free but you will use it a lot once you buy them.
Chris Pooley
Hi Juan,
Thanks for the reply.
I did not try that, I will try that on my next job.
Using the "Tree Model Simple 25" trees was a good solution as Lazlo suggested.
Thanks again
ArchiCAD 19 to 27
Windows 11
