Learn more
8 core Mac Pro
No more getting up at the crack of dawn, burning the midnight oil is also passé composé.
The 8 core Mac Pro has landed and Activity monitor (see screen capture) shown within ArchiCAD displays that a typical work load is now childs play.
((Aprils fool, just a spoof - I made the Activity Monitor panel in PhotoShop))
For now I am still in Dual Processor land, maybe some day - hey honey?
http://www.Apple.com
6 Replies 6
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Related article:
http://archicadwiki.com/Multiprocessing
Don't expect all cores to max out at this stage...
Gergely Kmethy
when then?
Dwight
By the time Graphisoft exploits the eight cores,
there will be 64 cores that run on solar power and you will post "When will we have sixty-four?"
Dwight Atkinson
At least the rendering portion should run at full tilt boogie, if Nemechek integrates the C4D rendering engine in future releases.
Letter to Maxon
Q:I was wondering, with the 8 Core Mac Pro, does the standard license
allow you to utilize all cores without extra expense? Thank for any
info.
A: Yes, it does. We do not node lock.
Maxon
With testing all bars go 100% with multiprocessors when rendering.
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
LightWorks is also multithreaded, although there are limitations:
http://archicadwiki.com/LightWorks
Gergely Kmethy
So if am I to understand correctly, when you need a high quality anti-alias, realistic sun image, (old school) ray traced large format image - then at that key point just prior to outputting an image for print - the Lightworks drops from a useful multi-threaded to a useless single-processor only.
O.K. that makes perfect sense Where can I buy a program like that.
