Visualization
Applying materials
Hi All,
I have a question regarding materials applying.
I'm applying some tiles materials and I want to know how do I choose where to start the tiles (e.g. which point will the tiling start from...)
I'm quite sure there's a simple way to do that since I once knew it but forgot
Thank you in advance...
4 REPLIES 4
Dwight
That will be the "Align 3D Texture" Command normally located under the Design Menu. You will do this alignment in the 3D window.
Dwight Atkinson
Thank you so much Dwight, you're the best!
You've helped me a lot, I was on the verge of suicide
Dwight
Glad to help.
It is terrible to forget.
But suicide? You exaggerate.
What the frustrated Archicad user does is not suicide:
they go over to Revit for a while to learn what real frustration is.
However, since we are both in a mood for exaggeration, here is how you might repay my favor:
Seeing as how you are in Italy, go to Marghera and kick Istvan Toth's ass for making Cigraph use dongles. [Insert favorite Italian cuss word here]
Dwight Atkinson
Consider it Done! On my way to Venice!
