ArchiCAD 16 and Artlantis 3?
Hi
AFAIK ArchiCAD 16 will only export to Artlantis 4.1. Is Gaphisoft likely to release an add-on to for allow this? I know Artlantis 3 is a bit old now, but not everyone can afford to buy new software every time they release a new version!
6 Replies 6
The Artlantis export add-on is developed by Abvent, makers of Artlantis, but bundled with ArchiCAD as a courtesy.
You'll need to post on the Abvent forums and/or contact their tech support. Here is the Artlantis import/plug-in forum:
http://www.artlantis.com/index.php?page=support/forum/liste&pages=1&fid=atl_import_us
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Ah. thanks for enlightening me Karl 😉
will post on the Abvent site.
You're welcome. Sorry that the response there only confirmed that there will not be an Artlantis 3 export plug-in for 16.
The solutions listed there to save as 3DS seem or save back to 15 (if possible). I believe you can still use the Reference File feature within Artlantis with a 3DS file, so that might be the best bet to stay as 'live' as possible...
Abvent has released an export plug-in for ArchiCAD 16 that saves in Artlantis 3 format. (They have also updated the plug-in that saves in Artlantis 4.1 format.)
Download here (usually the best bet is the source):
http://www.artlantis.com/index.php?page=download/plugin/index
or here (about halfway down the page):
http://www.graphisoft.com/products/artlantis/
Dennis Lee
It's about time! I'm glad they decided to do this.
Thank you Karl for keeping us informed!
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Thanks for the heads up Karl.
