Artlantis 3.0.6 update available
For anyone using Artlantis, Abvent has posted the 3.0.6 update to Studio and Render on their site...
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
5 Replies 5
Steve Jepson
Can Artlantis still import .3ds?
From the Help file:
Artlantis reads the following document formats:
ATL *, the Artlantis file format (versions 4.5 and higher), and AOF the Artlantis object format.
DWG/DXF the file format for AutoCAD 2010 and earlier.
DWF the file exchange format for AutoDesk products: AutoCAD Architect, Revit, 3DS Max, VIZ
3DS the file format for 3Dstudio versions 3 and 4.
OBJ/MTL file formats for Wavefront OBJ for geometry and MTL for associated textures.
FBX the file format for AutoDesk MAYA, 3DS Max, VIZ.
SKP the file format for SketchUp, versions 5, 6 and 7.
There are plug-ins for ArchiCAD, Vectorworks, Revit and Sketchup to natively export to Artlantis from those apps.
Karl
Steve Jepson
The reason I ask is because I can not "open" a .3ds files made with ArchiCAD in Artlantis 3.0.6.0 x64 and there is no Import funciton under the File menu anymore.
Rafal SLEK
You have to do it with 32+ Artlantis version then work with scene or media objects in v. 64+
64+ version is still Alpha.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD Collaborate
For some reason, i had trouble getting the updated Art•lantis Archicad Add-On to work. No worries, the old Art•lantis Add-On seems to work fine.
