Visualization
Artlantis 3.
Hey guys,
I know i have opened up a few posts lately but everyone here is excellent at replying.
I am using the new Artlantis, i used to use version 2 but couldn't download that, so i have opened up the new one with my Archicad file but for some reason, none of my lights are working!
They are all switched on. There is also no lights showing in the plan view that you can use to navigate like the one in version 2. I don't know if i have saved it properly or theres a different way to do it from the last version.
Any help would be greatly appreciated.
Thanks.
2 REPLIES 2
Dwight
Turn on the correct lighting group.
Dwight Atkinson
Hello guys, i need your help ASAP please !
im using windows 7 64bit
8gb ram and 1gb graphic
quicktime 7.6.9
archicad 14
the problem is :
i wanted to use artlantis 3 for my rendering,and i think i have replaced
the file add-on in export-import with the one i downloaded from myarchicad profile. the problem is i cant render using artlantis..it works fine but when i click render now it shows an error of (temporary.tga not found) i've done everything possible.. still the same.
might it be the problem when i replaced the add-ons files? bcoz it says its for archicad 13.. is that the problem? if yes then please how can i download the original archicad 14 add-ons for artlantis?
i tried different version of quicktime still the same,i reinstalled artlantis 3 and its still the same.. do i have to reinstall archicad14 again? and which quicktime should i use for archicad 14 64bit?
THANK YOU VERRRRRRRRRRRRRYYYYYY MUCH
