2006-11-2707:02 AM - last edited on 2023-05-1103:58 PM by Noemi Balogh
2006-11-2707:02 AM
Announcing:
THE BIDDING IS ACTIVE ( OPEN TO EVERYBODY - NO NEED TO PRE-REGISTER) FROM NOW UNTIL DECEMBER 15th. SUBMIT YOUR BID BY COPYING THE ENTIRE TEXT BETWEEN THE ASTERISK AND ADDING THE MISSING INFORMATION.
GOOD LUCK and HAVE FUN!
IF YOU JUST SAW THIS EVENT TODAY, FOLLOW THE DIRECTIONS BELOW TO SUBMIT YOUR BID FROM TODAY UNTIL DECEMBER 15th!
You can follow the progress of the bidding at the above post. I will try to post the names of the highest bidders (without the value of the bid) - this will let you know if you need to submit a better bid. I will do this as often as possible, please understand I am not eBay and I cannot post it several times a day.
