2007-10-17
06:37 PM
2023-05-11
01:09 PM
Noemi Balogh
2007-10-19 12:48 AM
2007-10-19 01:04 AM
Thomas wrote:To set up the default templates, simply copy a material (eg. whitewash) multiple times and name them like 'Default External Wall', 'Default Column', etc. This is easy done in the Attribute Manager. Then in your template set up your tool defaults and/or favorites to use these materials where appropriate, so that everything you create uses these default materials.
But Link: Please detail your bulk material switch procedure a little- it seems like a brilliant tip , but I don't follow you completely, and I'm scared of material confusion - I've had too many "missing library part" dialogs in my life!
2007-10-19 08:01 AM
2007-10-19 09:24 AM
Link wrote:This tip is all sweet Link!Thomas wrote:To set up the default templates, simply copy a material (eg. whitewash) multiple times and name them like 'Default External Wall', 'Default Column', etc. This is easy done in the Attribute Manager. Then in your template set up your tool defaults and/or favorites to use these materials where appropriate, so that everything you create uses these default materials.
Once you have finalized the material, switch it out by changing the material definition, or by using this method.
Link.
2007-10-19 10:03 AM
2007-10-19 10:10 AM
2007-10-19 10:29 AM
Thomas wrote:You're to focused on butts...early friday syndrome perhaps...
Good idea, Mats!
But... All But Glass? All, But Keep Transparency? ...
Well. Still a good idea!
