Center render on screen when marquee
I wonder if there is a way which I can view the render image center in the screen not fixed in the upper corner. It is not a big problem but very annoying
Erwin Edel
You can minimize or whatever it is called (undock from the tab list) the view and then move it where you please within the workspace of ArchiCAD.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thank you I know, but I wonder if there is any set up that display the render in the center of the layout instead of moving it.
