Create Fly-Through bug
I'm on AC12 and the writing is on the wall; need to upgrade.
I've setup a camera path to render (with Lightworks) a fly through but no matter what i do, when i run "Create Fly-Through" i lose my sun settings.
I can run a single rendering and it works but the moment i go to fly it starts rendering without sun.
Sun settings don't stick at all. i have to reset them every time to do a single rendering but fly throughs just dont work.
I generally have trouble keeping settings locked in under 'more sun'; have to hit 'daylight savings' check box to un-grey the sun position settings but the problem above re occurs.
is there a known bug in Lightworks?
Looks like the bug was mostly me.
A good nights sleep reset my brain and resetting Lightworks to factory settings reestablished the proper base line from which to tweek settings.
Making progress!
