Visualization
Crop view of Modules
In AutoCad one can crop the view of an x-reference with the xclip command. I cannot seem to find if you can crop an archicad module. I want to see only a portion of the plan and not the whole plan in the module I have placed in another file. Can I do this? How?
Thanks for any help.
David Rulon
Windows XP Professional Version 2002 Service Pack 2
Pentium (R) 4 CPU 3.00Ghz ! GB RAM
Archicad 9.0.0.8306
Aussie John
sorry but I dont believe you can directly.
I suspect you could re export from Plotmaker using the "save cropped info only" setting. I havent tried that.
Personally I like to use a separate file to original for the xref as I can put a "zz" at the beginning of the file name so it lists at the end of my layer list.
Cheers John
[/size]
Not directly possible, but can you give a little more context so that one of us can suggest a workaround?
I assume you are hotlinking a module that contains 3D model information? Will your cropping cut through model elements (e.g., walls), or simply isolate disconnected elements? Or, are you only concerned with 2D?
AC 28 USA and earlier   •   macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
