‎2025-02-16 08:38 PM
I encounter a problem with 3D view display in archicad. Each time I move a mouse coursor in the 3D view the editing plane/grid is "blinking" and kind of overlapping the actual object. I need to stop mouse a the object and wait few seconds so it can be checked. Please check attached video. Has anyone had similar issue?
I'm running Windows 10, with NVIDIA K1100M with latest drivers.
Operating system used: Windows 10
‎2025-02-16 09:09 PM
Is this issue new? Did you do any updates on the graphic card maybe that started this behavior?
I have looked up similar issues and that seemed to be the culprit.
Namely:
https://community.graphisoft.com/t5/Modeling/3D-window-flickers/td-p/366588
https://community.graphisoft.com/t5/Installation-update/Flashing-in-3D-modeling-views/td-p/223207
Hope this helps.
Maybe you ought to check that.
