Error Code 215 Not enough memory to cut 3d model
So I have been running the lightworks fly-throughs daily(nightly, they take a long time to render) all week 1341 frames about 2 1/2 min. 4" wide(small) animation. I have gotten the error code 215 every time, but at the end and it didn't seem to effect anything. Now I am getting it earlier. I have added and modified lights since the previous runs, but it still seems strange. I have had the same results on both my laptop(G4) and desk top(G5, 2x2.0ghz, 1.5g) Any thoughts?
4 Replies 4
Dwight
merge the file into a new project.
Dwight Atkinson
I have a new hero and you are he.
What does merging into a new project fix?
Thank you,
Dwight
Back in the good old college days of punch cards and standing in line to hand those punch cards to a surly operator, when there was a typo on one punch card, you didn't get a wonderful wireframe perspective, you got twenty pages of erroenous error messages that talked about everything but typos, since professional programmers never make typos.
These were pocket protector days.
Punch cards were funny. Guys carried their projects in long cardboard trays. Getting into cars, you'd store your coffee and punch cards on the roof while you thew your book bag into the backseat of the carpool car and then forget. Guys would be driving home, a stream of cards dancing out and up behind the car, landing in spilt coffee.
When you see an error message, all you can be sure of is that something is wrong - it could be a program error or a file corruption - who knows? Who cares? Merging makes ArchiCAD re-read the data and somehow it gets reorganized. I learned this trick beta testing some software where you could never re-open a file because of some wierd issue. Merging would work, tho.
It helps to know voodoo.
Dwight Atkinson
Thank you,
Yes, when You merge, ArchiCAD checks the merged data and tries to fix it if possible. If not it will delete it, but chances are that merging will make most of file usable again. Very handy trick to know.
